Delete Companion Results with NX Open Python
Is it possible to delete companion results within a Python journal?
I tried recording a delete which generated the following code:
# NX 10.0.0.24
# Journal created by u566264 on Mon Nov 02 16:14:36 2015 GMT Standard Time
import math
import NXOpen
import NXOpen.CAE
def main() :
    theSession  = NXOpen.Session.GetSession()
    workSimPart = theSession.Parts.BaseWork
    displaySimPart = theSession.Parts.BaseDisplay
    markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Delete Companion Result")
    simSimulation1 = workSimPart.FindObject("Simulation")
    simSolution1 = simSimulation1.FindObject("Solution[Thermal Steady State]")
    simResultReference1 = simSolution1.Find("Thermal")
    companionResult1 = simResultReference1.Find("CompanionResult[tmg Act-A]")
    simResultReference1.CompanionResults.Delete(companionResult1)
    #   Menu: Tools->Journal->Stop Recording
if __name__ == '__main__':
    main()
However, trying to run this yields the following error:
AttributeError: 'NXOpen.CAE.SimResultReference' object has no attribute 'Find'
I can't find any delete methods in the API for companion results. Does anyone know how to do this?
Peter
Re: Delete Companion Results with NX Open Python
SimResultReference seems like it may have a couple of bugs in it. Please contact GTAC and file a PR.
In the meantime, give the following a try:
import sys
import traceback
import NXOpen
theLw = theSession.ListingWindow
def main(*args):
    simPart = theSession.Parts.BaseWork
    try:
        # Add your application code here
        theLw.Open()
        activeSolution = simPart.Simulation.ActiveSolution
        theLw.WriteLine("Active Solution: " + activeSolution.Name)
        resultRef = activeSolution.GetResultReferenceByIndex(0)
        companionResultCollection = resultRef.CompanionResults
        for companionResult in companionResultCollection:
            theLw.WriteLine("  Deleting companion result: " + companionResult.Name)
            companionResultCollection.Delete(companionResult)
    except Exception as ex:
        # Show the exception in a Message Box
        theUI.NXMessageBox.Show("Hello World Exception", NXOpen.NXMessageBox.DialogType.Error, str(ex))
        # Write the exception to the listing window
        theLw.Open()
        theLw.WriteLine("ex:")
        theLw.WriteLine(str(ex))
        # Print the exception to the syslog
        print(ex)
        # Write the traceback to the listing window
        theLw.WriteLine("")
        theLw.WriteLine("traceback:")
        theLw.WriteLine(traceback.format_exc())
        # Print the traceback to the syslog
        traceback.print_exc()
    except:
        print("Unexpected error:", sys.exc_info()[0])
# Main program.
if __name__ == "__main__":
    main()
Thanks Jim,
To make it delete all companion results rather than every other, I have replaced the for loop in your code with the following:
        results = []
            results.append(companionResult)
        for myResult in results:
            companionResultCollection.Delete(myResult)
Where do I go to submit a PR?
Peter
CAE.SimSolution.ResultReferenceCount() is suppossed to return the number of results so that you can loop over them all using CAE.SimSolution.GetResultReferenceByIndex()
However, I get a fatal error when calling ResultReferenceCount(), so I hardcoded the index to 0 in GetResultReferenceByIndex().
PR 7555094 was submitted on the ResultReferenceCount error.
 results = []
        for i in range(0, len(results)):
            results.pop(i)
just another way to write it. or use a slice index
del results[0:lastpos]
or remove the specific element
results.remove('nameofelement')
