Distributed Parallel Execution failure
When trying to run a solution in parallel on one machine the DOMDEC module fails after the MEREL module.
 Cpu time=     95.1      MEREL Module
   Performing element merging and elimination...
     No. of elements merged:      1340, for details please see file REPF.
   ...done.
QProcess Error: module terminated
 | Distributed Parallel Execution: DOMDEC - Domain decomposition setup:
 |  encountered a problem and terminated abnormally.
 |                                END                                 |
I have tried reinstalling SMPD by running mpich2-1.4.1p1-win-x86-64.msi as an administrator from the tmg folder. This didn't seem to help.
Parallel processing stopped working once in the past but spontaneously started working again after a couple of days.
Does anyone know why it isn't working?
Peter
UPDATE: This computer has virtual processors and parallel running of the same model works on another desktop without virtual processors. Could this be the issue?
Re: Distributed Parallel Execution failure
Hi Peter,
Did you find the solution for this kind of problem ? I have the same one as yours.
Thank you,
ngda
