cancel
Enforced Pressure to fluid grids
Hello everybody,
I would like to impart enforced pressure to fluid grids in my frequency response analysis ( Sol 111 ).
Should I use SPCD for the same? I am bit confused since fluid has got only single dof, how shall we use?
Thank you in advance
Re: Enforced Pressure to fluid grids
Fluid grids are scalar points that have only 1 DOF (pressure). If you specify a SPCD on DOF 0 or 1, you will be specifying the enforced pressure at that location.
If you have power data, you can use ACSRCE to apply that to a fluid grid.
Jim
