Export NX motion to teamcenter visualization (.vfm file)
Hello!
I am attempting to export an animation (kinematic motion simulation) from NX motion simulation to a .vfm file viewable in teamcenter visualization. I am able to export it, but i get broken references when I try to load the exported file. Does anyone have a similar problem/solution?
Thank you!
Re: Export NX motion to teamcenter visualization (.vfm file)
I don't get such issue. Is it when loading the JT file in teamcenter visualization or when opening the .vfm file, or in the playback?
Cheers
Gilles Dubourg
Product Manager – Simcenter 3D Motion
Product Lifecycle Management
Siemens Industry Software SAS
gilles.dubourg@siemens.com
www.siemens.com/plm
It happens when I load the .vfm motion. A reconicle references dialouge appears and the motion playback window appears. However, there are no steps viewable in the motion window.
Thank you!
I know this is a very old thread, however I'm getting the same issue.
I'm creating the vfm file from NXopen and getting the same issue.
If I open this in jt2go or visview I get an extra node at the very top called the same as the vfm file name so in my instance it's call output.vfm
If I export it from the UI it works fine and the top node isn't present and the vfm imports into TCVis and plays back.
With the
I managed to solve this by using NX11 to export the jt and vfm file.  It is a known bug in  NX10 and below.
