Field by ElementID
Dear experts,
I perform an external fatigue calculation and then I plot in NX a utilization factors with a pressure field.
Is it possible to create a field by "ElementID" in the independent domain?
Re: Field by ElementID
Yes, Element ID is an available independent domain
Hello JimB,
I´m searching the options for independent domain and I have only found de Node ID.
I work with elemental stresses and I would like to use it in order to plot the fatigue utilization factors.
I use the NX in spanish.
Sorry. ElementID will be an available independent domain in NX 11. It is not in 10. You can use Parameter as an independent domain in NX 10.
Thanks JimB, I will be ready to update to NX11.
