Formula field in NX
When I am trying to apply the thickness to the plane stress element through formula field I am getting an Error messgae "Specified independent variables do not define a valid domain".
Can anyone please explain what does it mean.
Independent variable are Cartesian, asnd dependent is length which is a function of x and y.
Re: Formula field in NX
Saddam,
Attached is an example in NX 10.0.3 of a plane stress mesh using a cartesian field to define its thickness. The mesh is in the XY plane and the thickness field is simply (x+y).
Mark
