Do you mean
Reply
Get result from Calculate Area function
Hi there,
I'm programming something to give me the projected area of a body. I have made a journal to calculate it through the 'Calculate Area' function in the Mold application. When I run my program, everything works and I'm getting a notepad window with the results. Now my question: how can I get the resulting area value into a variable? By debugging, I'm not seeing where I can obtain the resultvalue. Can anybody help me please?
Alexander
Re: Get result from Calculate Area function
Are you asking if you can get the output of the  'Calculate Area' function to a/your variable? How are your "printing" to the LW?
Hi Alexander,
you can save the content of the listingwindow to a file using
  ufs.Ui.SaveListingWindow(fspec)
where fspec represents the complete filename.
Afterwards you can read the textfile and find the projected area value
Best regards
Frank De Mets
This works well. Thank you, Frank De Mets!
With regards,
Alexander Priem
