cancel
How to allocate a different temperature to each elements
Hello everybody,
I'm actually using Nastran NX during my internship ans i'm searching how to allocate a different temperature to each elements. I didn't know Nastran before my internship, that's why i have some problems.
Here is the probleme.
I have a solid 20*20. I want to allocate a chosen temperature to each elements of the solid. I reached with a solid 4*4 by using temperature with spatial distribution field (table) that i created.
But when i tried to do the same thing with the 20*20 solid, the solver crashed and i don't know why because i did the same thing that with the 4*4 solid.
Can I did it differently ?
Thank you for your help.
Re: How to allocate a different temperature to each elements
A spatial field should be appropriate for this. You'll need to provide more information about the problem the solver encountered. There is no fundamental reason that this should not have worked.
