How to couple a thermal and structural analysis in NX?
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
I am trying to solve a thermal solution and structural deformation simultaneously.
I know I can map a thermal solution to a structural solution and use that temperature map as a pre-load after the fact that the thermal solution is completed. However, I need both to be coupled an solved simultaneously (or at least close to being simultaneous), as transient solution.
e.g. For time step 1, solve thermal solution as sub-steps --> feed solution to structural analysis --> solve structural solution as sub-steps --> feed solution for time step 2--> solve thermal solution for time step 2... etc....
It seems it is possible to do so in NX nastran. But I cannot find any steps for doing that. I tried using NX Nastran and NX Multiphysics. But both only allow me to do either a structural or thermal analysis separately.
Does anyone has any suggestion? Does it require any special license?
Thanks!
Elaine
