How to run a bat-file in a linux server using acoustic solver?
Guys please help me with this.
I just install a acoustic solver in the linux server.
I open VL in windows and my CATAnalysis, launch my case in manual mode (files are saved in the specified directory, no calcualation is done), save my CATAnalysis and close VL.
Then I go the specified directory and try to launch the calculation manually (e.g. by launching the bat-file).
The question is.. how i want to launch the calculation manually? what file should i run? are there any command to execute it ?
Re: How to run a bat-file in a linux server using acoustic solver?
You need to run*.bat file to execute analysis
actly, for the pre-processing part im doing it in the windows.
and for processing, im using acoustic solver in the linux.
when i do the manually, the file is save in the linux or windows? i mean the *.bat file.
you can check the files in the default path
The default pathc can be changed go to
Tools-->Options-->General-->Function Display
okey. thank you so much
