Import PCB board from eagle
I have been trying to import some PCB from eagle to NX10, I have some results when I import it by means of IDF files, but in this way I only get the external geometry of the board and I am interested in getting as well the inner copper layers.
Although I know I can define the physical properties (material, thickness, vias…) of the layers during the meshing process, I would  also like to have the geometric layout of them for the thermal simulation, do you know if this is possible? I have also tried to import a .brd file directly to NX but a error message “bad profile board” appear every time.
Thank you in advance!
