Impossible to select Nodes in assembly fem
I am new to assembly FEM but have established an AFM file into which I have loaded one FEM file, –the Davit Arm. The Davit Arm FEM is orientated as required and I would like to do some manual meshing for the supporting structures. Problem is that the nodes I make displays, but I am not able to select them for manual meshing. It is also not possible to select them for deletion. Any suggestions?
The FEM and AFM file is attached
Geir
