Do you mean
Reply
Solved! Go to solution
Is possible to use SOL 200 for topology optimization?
[ Edited ]
Hi all,
Is possible to use NX Nastran SOL 200 for optimizing the topology of a part? for a static case SOL 101 and later launch a second case with SOL 200. I want to recude the stress and volume too. How can be customised the SOL 200 on NX CAE window?
Thanks, Igor.
Solution
Solution
Accepted by topic author Igor
‎08-26-2015 04:32 AM
Re: Is possible to use SOL 200 for topology optimization?
Hi Igor,
Sol200 id not supporting topology optimization.
Do you have any manufacturing constraints that have to be considered?
Boris
Hi Boris,
I want to reduce volume and optimise stress, I know some sheet metal parts that can have a volumen reduction.
On the other hand, I have seen some FEMAP with NX Nastran videos with topology optimization. Is Femap using a different solver engine or plus other optimisation solver? Attached a video.
https://www.youtube.com/watch?v=-NC6jCIUwIw
Thanks, Igor.
