cancel
Journal for change color elements
Is there any journal that could change the colour of all elements in a FEM model, for example Tetra elements=Green, Shells= Yellow, CBAR=Red etc and you can change on VB journal element color.
Thanks.
Re: Journal for change color elements
I have an old application that will change element color based on the mesh, mesh collector, material or physical property. However, in later releases, this functionality is available in the out of the box command Model Display Preferences, which also allows you to color elements based on element quality check results:
