Key Frame Animation
Is there a way to create an animation in NX 9 without the need for setting up joints and driving motors similar to sequencing for the assemblies though that doesn't appear to get me there either.
I want to animation by moving the components establishing a key frame and having the software blend across to the new position based on frame count to the next frame I create.
Basically taking arrangements as the key frame and having it animation from one arrangement to the next. Just as someone would do in true animation software like Maya or Blender, but in a much more simplified format in the case of just moving components around.
