MEREL and DATACH modules crash without reason
When solving with NX-Thermal, the DATACH and MEREL modules end abnormally, causing a fatal error. This happens 3 out of 4 times the model is run without explanation, and runs fine the rest of the time.
Does anyone know what could be causing this?
Peter
Re: MEREL and DATACH modules crash without reason
This was fixed by updating the solver to the latest version of TMG.
Hello Peter, we had a similiar problem.
How did you upgrade the TMG solver? Did you install an NX maintenance pack or did you find a specific patch for the TMG?
Thanks!
S
On Siemens Global Technical Access Centre we navigated to:
Product update --> Thermal Flow --> NX10
Then downloaded TMG version 10.0.295
Peter
Thank you, Peter!
S
