Mapping of transient Thermal/Flow solution
I have a transient Thermal/Flow solution, which writes out a result every 10minutes.
Now i map the solution to a Nastran SOl101 and the solver takes always the last result of the transient solution.
Is there a possibilty to take the thermal field at a specific time? for example after 10minutes?
Or can i map all results of the transient Solution and get the mechanical deformation for each 10minutes time step?
Thanks for your the help.
