Do you mean
Reply
Solved! Go to solution
NX 9 Flow simulation problem
Hi everyone,
when trying to do that example " https://www.youtube.com/watch?v=RtI_aGf4J1E&list=PL242F63B1B36E55F7&index=15 "
i get the following error during the process.
Unknown option: -d
Error while connenting to host, No connection could be made cause the target mac Connect on sock (host="computer name", port="****") failed, exhausted all end points sock error: Error = -1
any solution? thank you.
Solution
Solution
Accepted by Ganesh_S (Community Manager)
‎08-26-2015 04:32 AM
Re: NX 9 Flow simulation problem
Aitch,
You need to get the NX9 patch which is at:
https://download.industrysoftware.automation.siemens.com/unigraphics/thermal_and_flow/NX9
Phil
Philippe Tremblay
phillippe.tremblay.ext@siemens.com
www.mayahtt.com
Phil,
thanks alot for answering.
when i open the link and enter my username and password. an authentification step appears. have to enter both again, but it doesn't give me access
