NX CAE Reports
I want to know how can I save NX CAE Reports. I can create it, but I don't know where is saved the .HTML files.
Re: NX CAE Reports
Dear Igor,
If you generate the report you will see the path directly in the HTML browser:
Best regards,
Blas.
WEB: http://www.iberisa.com
Re: NX CAE Reports
Hi Blas,
Can I change the default path directory on NX CAE?
I want to save the report files on C:/NXCAE/Reports/Project folder name ot general path.
Thanks in advance.
Re: NX CAE Reports
Dear Igor,
I am not aware of any environment variable to control the report location. The NX CAE report is written to a number of HTML and graphics files, and stored in your local temp directory. When the files are written, the software launches your default browser and displays the resulting report.
You can save later the report in any directory you like using FileSave As in your WEB browser to save the report to a permanent location.
Best regards,
Blas.
