cancel
NX Drafting
Builder
Builder
I would like to define a new titlte block (I managed to do that), and then define a template (I suppose), that will include the title block, in the correct position on the page, and that will work such as, when I create a new draft, I can select that template, populate the title block and, after that, create the projections (a similar workflow I am using in Solid Edge or Solid Works).
Many thanks
Ionut
Re: NX Drafting
A much better place to ask this question would be the design forum.
