cancel
NX Durability Vs FE SAFE
Hello Everyone..
Can anyone explain me how strong is NX CAE in Durability when compared with FE SAFE & MSC Fatigue??? If anyone has worked on both.
Amit Nandi
Application Engineer, DesignTech Systems Ltd.
Re: NX Durability Vs FE SAFE
Siemens Genius Siemens Genius
Siemens Genius
Dear Amit,
of course we know and have analysed other fatigue tools, but we do not exchange this information here.
I  send you a prrivate message.
Best Regards
Michael
Dr.Michael Hack
Business Product Line Manager Durability
Simulation and Testing Solutions
Hi Michael
Yeah please and thank you
Sent from my iPhone
Amit Nandi
Hello.
Can you send the document also to me?
BR
Siemens Genius
Dear,
competitive, positioning, and strategic information is handled confidential inside our company.
These community pages are also not meant for global marketing, but to help you solve your problems.
If you have concrete questions on capabilities, we are of course happy to help you.
BR
Michael
Dr.Michael Hack
We use NX nastan for the electrical component like fuse-box, cable and want to know about NX Advanced Durability.
Siemens Genius
Dear,
what would be the durability load scenario, you are interested in ?
Is it a shaker table test ? Random, sine sweep ?
Are there more complex mechnical entities like switches ?
What loads do you apply to the cable ?
Are there defined durability requirements ?
BR
Michael
Dr.Michael Hack
We have PSD profile to test and complex mechnical entities like switches normally model as mass.
Siemens Genius
Dear,
so I under stand you model the shaker test of the component. For this we have two technical papers which you can download from researchgate:
https://www.researchgate.net/publication/270917706_Multiaxial_Load_Situations_in_Random_Vibration_Fa...
https://www.researchgate.net/publication/283482900_White_paper_Vibration_fatigue_simulating_durabili...
Hope this helps!
BR
Michael
Dr.Michael Hack
Michael,
Assume that one wants to do a simple fatigue check (by hand calc) using well-known method eg Steinberg
What is the implication of a low Irregularity factor i.e. when the response signal tends toward a white noise?
