NX batch meshing
Hi all?
I have seen a PDF that NX9 can create batch meshing.
My question is, how could NX9 create batch meshing process? how could be evaluate element quality after meshing?
Thanks in advance.
Re: NX batch meshing
Did you already check this folder NX 9.0\UGOPEN\CAEBatchMeshing in your NX installation?
Siemens Legend Siemens Legend
Siemens Legend
Hi IgorNX,
You will find the Batchmeshing Executable in the UGII folder of the NX installation.
'%UGII_ROOT_DIR%\ugnx_batchmesher.exe
You can use the following commandline options:
–part=partname
–p=parameter-file-name
–c=criterion-file-name
–t=template-file-name
–solver=solver-name
–no_idealize
–fem
–dat=extension
–jt
–key_word=keyword-string
More detailed information on the utility can be found in the NX help, just search for "Batch Meshing Utility".
The batchmesher generates a log file where you can find information about mesh quality,...
Boris
