NX memory Error
I had this message when I try to run an analisys
anyone has any idea to fix it???
Re: NX memory Error
Innovator
Innovator
Hello!,
This is a typical error when not enought RAM memory exist in your computer, in the old times of the 32-bits OS it was very usual. Make sure to run a modern 64-bits OS and enough RAM memory, say minimum 8 GB RAM.
Best regards,
Blas.
Re: NX memory Error
Thank you sir...
