NX11 Parallel Flow Solver with High Speed Flow
Hi everyone,
I am having trouble using the PARALLEL solver with "high speed flow" enabled with my gas (helium). The simulation is valid and works to completion with good results using the SERIAL solver, but everytime I try to run the exact same simulation switch to PARALLEL I receive:
+____________________________________________________________________________________________+
NX2TMG - FATAL ERROR 1790
High speed flow only supports calorically perfect gases, but no such gas was selected. The solve is aborted.
But no changes have been made between the serial solver run and parallel solver run. Same mesh, same material, looking at info sheet for Helium shows that it is calorically perfect. I even made a custom helium material with specific heat set to a constant value for everything, still same results for every type of settings.
Please, any advice!
