cancel
NXopen_Get all collectors
How to get list of all collectors in fem file with NXopen methods?
Re: NXopen_Get all collectors
 Alexander,
You get these from the FEModel. VB Code:
Dim myFemPart As CAE.FemPart = theSession.Parts.BaseWork
Dim myMeshCollectors As New List(Of CAE.MeshCollector)(myFemPart.BaseFEModel.MeshManager.GetMeshCollectors)
Jim
Thank you . I will try this.
Hi Jim.
I havn't work with list objects much and meet with error with your code in list initialization.
But if use an array , than it works fine :
'Dim myMeshCollectors As New List(Of CAE.MeshCollector)(myFemPart.BaseFEModel.MeshManager.GetMeshCollectors)
Dim myMeshCollectors() As CAE.IMeshCollector = myFemPart.BaseFEModel.MeshManager.GetMeshCollectors
theLW.WriteLine("There were found :" & System.Convert.ToString(myMeshCollectors.Length) & "collectors in file")
For i As Integer = 0 To UBound(myMeshCollectors) Step 1
theLW.WriteLine("Collector # :" & System.Convert.ToString(i + 1) & " has name : " & System.Convert.ToString(myMeshCollectors(i).Name))
theLW.WriteLine("Collector # :" & System.Convert.ToString(i + 1) & " has type : " & System.Convert.ToString(myMeshCollectors(i).CollectorType))
Next i
