Output results in NX10
Builder
Builder
After running a nonlinear case, I would like to be able to see the results for any particular time step. That is, if the total time step is 1, I would like to see the response at 0.5 for example. This will allow me to evaluate a time evolution of the analysis.
Many thanks
Ionut
Re: Output results in NX10
for SOL106 you need to go to solution properties, in NLPARM change as follows:
In SOL601/106 you should get results for each time step by default.
for solution 601 you have to activate a "Time Step Interval" in Solution parameters as described in
http://community.plm.automation.siemens.com/t5/NX-CAE-Forum/Model-different-tensile-and-compression-...
see Picture:
http://community.plm.automation.siemens.com/siemensplm/attachments/siemensplm/NXforSimulation_forum/...
Best wishes,
Michael
