cancel
Point Mass (CONM2) from 3D geo?
To all
Does anyone know if there is an option in NX.CAE 9 to use 3D geometry to create a Point Mass (CONM2) directly (or by association)? By that I mean by selecting the 3D geometry, NX automaticaly creates  a CONM2 at the CofG (of the selected geometry) with "correct" associated data (mass, inertia, etc) and this CONM2 could even be associated with the geo(!)
Re: Point Mass (CONM2) from 3D geo?
Not out of the box, but the attached NX Open application does what you are looking for.
Password for the .zip file is "cae"
Thanks for that JimB. Having problem downloading the file but will try later from another machine
Jimb. Managed to download the zip file but all its content it password protected so cannot unzip it.
Sorry about that. I edited my original reply to include the password.
Dear Jim,
Very useful, thanks!, but when I try to run the DLL using FILE > EXECUTE > NX OPEN > and I get the following error:
Any help is welcome, thanks!.
Best regards,
Blas.
WEB: http://www.iberisa.com
The .dlx file must be in a location where NX can find it. This is in a subfolder named 'application' located under a user directory specified by UGII_USER_DIR or in any directory specified in UGII_CUSTOM_DIRECTORY_FILE.
See the "Environment Variables" and "Application Directory Structure" articles under "Executing NX Open Automation" in the NX Open Programmers Guide.
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_api/#uid:index_nxopen_prog_guide:id1142131:gen...
Dear Jim,
Running OK, thanks!.
Best regards,
Blas.
Thanks for the provided .dll. Much appreciated
Creating lumped masses directly from polygon geometry is in the NX 11 plan. The NX Open program formed the basis of the OOTB project work that is currently under development. So, you can retire the use of the NX Open program in a year or two. A benefit to the OOTB application is that the polygon geometry based lumped masses will update automatically when the geometry updates.
Mark
Mark Lamping
Simulation Product Management
Product Engineering Software
Siemens Industry Sector
mark.lamping@siemens.com
