Do you mean
Reply
Solved! Go to solution
Problem Obtaining Center of Mass Velocity, Acceleration and Displacement
Hi, I'm new to this forum but I have this hard problem of obtaining the velocit, acceleration and Displacement of the center of mass of one of the links of my assembly.
I already did the solution for a rotational load with 3000 rpm and got some results. Now the problem is that I need to plot\graph the Displacement, Velocity and Displacement of the center of mass. I found that is possible, see attached image from NX advertising.
It states that I need to select the center of mass of the link and then graph the Velocity, Acceleration and Displacement of the center of mass but I cannot find how to do that, the only thing I have found so far is how to make a graph for a desired node of the FEM analysis but that is not what I want. I need a velocity vs time, acceleration vs time and displacement vs time graph.
Thank you very much for your replies.
Re: Problem Obtaining Center of Mass Velocity, Acceleration and Displacement
Hi Juan,
Sorry many of us are on vacation right now so sorry for the delayed response, but I am checking with some colleagues and try to get back to you with an answer!
Ganesh
Simcenter 3D Community Manager
Simulation and Test Solutions
Solution
Solution
Accepted by topic author Juan_Engineer
‎08-26-2015 04:32 AM
Thanks for your reply.
I already found the solution and my solution is as follows:
I was trying to get that from simulation and fem analyses so I couldnt do it there. I needed a motion simulation in order to get those graphs.
