Problems Using Adaptivity for Mesh Refinement
Hello
I have an FEA problem that consists in a flat plate with a load and a boundary condition aplied (see image attached). I need to determine the stresses, deformations and displacements. I'm trying to use the command Adaptivity Setup of NX to do a mesh refinement, so I can check if the analysis converged. The problem is that I cannot see the results of my simulations to check Strain Energy Norm. Before the Adaptivity Setup icon, in the Post-Processing Navigator appears a red circle (see image attached)! Do you know how can I get the results? And, I only started using NX for a few days, so do you know a better way to do this kind of analysis?
Best regards,
Filipe Caldeira
