Renumber nodes
N/A
I need to renumber nodes in NX Advances simulation.
How to do this?
Juraj
Re: Renumber nodes
N/A
"Juraj Zahradnik" wrote:
>Hi,
>How to do this?
>Juraj
Juraj,
The .fem should be your Work Part. Then use Edit, Node, Modify Label from the menus.
You can also turn on the Node Operations toolbar and use the Node Modify Label button
on it.
If you don't see either of these commands, open the Roles tabl on the navigator
and set your role to "Advanced with Full Menus"
Jim
Re: Renumber nodes
N/A
Hi Jim,
thank you for advice. I found this icon in toolbar and it works good upwards. But,
if I have nodes in range e.g. 300-400 and I want to renumber them from one, it doesn't
work. To know how to solve this task - I wouldn't have no comment.
Juraj
>>Hi,
>>How to do this?
>>Juraj
>Juraj,
>the menus.
>button
>on it.
>Regards,
>Jim
