Reset IDs of Material and Physical Properties
Hi everyone,
is there a possibility to reset the IDs of the material and physical properties similar to the existing "Reset Node and Element IDs"?
Modifying each label by hand is possible, but not really convenient if lots of entries exist...
Thanks for your hints!
aae
Re: Reset IDs of Material and Physical Properties
There is no out of the box command to do this. It could be accomplished with an NX Open journal.
Ok.
Thanks Jim, I feared this answer, because I´m not very familiar with it.
But I will try...
Community Manager
Hi @aae,
Here's a few things to help you get started with NX Open (if you're not already aware of them):
The NX Open Programmer's Guide introduces you to topics around this area.
There's also an NX Programming and Customization forum. People there can lend you their expertise if you get stuck, and they probably have some more resources to help you! Smiley Happy
Best Regards,
Amy Allen
Product Engineering Software
Siemens PLM Software, Inc.
