Reset node and element numeration
I am interested if there is a possibility to reset the node and element numeration in fem files.
I had a part meshed with quadratic elements lets say with node numbers from 1 to 80000. I changed the element type to linear elements. Therfore it looks like that NX is starting the node numbering at 80001 upwards.
Is there an option to reset the starting point for numbering the nodes?
Thanks!
Georg
Re: Reset node and element numeration
Yes. With the FEM as the work part, RMB on the FEM on the Simulation Navigator and pick "Reset Node and Element IDs":
Thanks again! :-)
