Results Inside the object
Hello everyone,
I'm new to NX Nastran and I need your help !
After a simulation, I would like to see results ; like stress ; "inside" the system. So I use the Section tool but it only shows the section in yellow.
I would like to see the stress inside the component.
I tried to change settings but impossible for me to find the right option.
Can somene help me ?
Thank You !
Re: Results Inside the object
Arthus,
In the Results tab, click the Edit Post View button. Then select Display on Cutting Plane.
Phil
Philippe Tremblay
phillippe.tremblay.ext@siemens.com
www.mayahtt.com
