SOL108 for different forcing frequencies
Backround
-I want to perform direct computation for 2 different frequency range(Ex. 20-30Hz and 40-50Hz).
-Both frequency range have different loads to be applied
My Question
-What is the quickest way to perform this in one run?. Normally I would create 2 different solution to cater for one frequency range and apply the appropriate forcing frequency.
-Can I use subcase to perform this? What is the common use of subcase?
