Simulate free convection
How to simulate free convection of a body enclosed inside a box?
I want to simulate convective heat transfer for a small sphere that is enclosed within a box containing air at high pressure.
How to do this? How to define air pressure inside the box?
Re: Simulate free convection
Hi, Mrinal_Mani!
I met the same problem as you did here. Have you got the solution to this problem?
I have no idea to set resonable flow boundary conditions to describe such free convection in limited chamber.
Thanks so much for any clues.
One way to do that is to initialize the pressure. Go to Home --> Loads and Conditions --> Constraints --> Initial Conditions to set the initial pressure of the air domain.
