Do you mean
Reply
Simulation for loading on vehicle suspension
I am doing a 4.5G bump load case on a car suspension which I want to study the deformation and structure of it. I am confused about the loading that I should put into my model because in reality, this 4.5G bump load is absorbed by the shock therefore the load that the suspension structure experience is less than 4.5G. Since the bump load is dynamic, how should I find the maximum load in the bump motion so that I can put it into a static analysis?
Thank you
