Space system thermal: how to extract previously unselected result without rerunning the solution?
If I after running a solution would like to extract a result not being selected in the result options, is it any way to extract the result without having to rerun the solution?
Lars
Re: Space system thermal: how to extract previously unselected result without rerunning the solution
I think that this is not possible. For example, view factor between two planes is possible to determine by including these planes in "Report" (Simulation object type) before solver start.
