Temp Preload from OP2 with relative path
Hello experts,
is it possible to define a temperature distribution in "Linear static Sol 101" via
"Temperature - External Time Unassigned"
without selecting the op2 file by setting an absolute path?
I would like to use something like
"..\dir_of_HeatTransfer\Modell_prt1_fem1_sim1_Heat_transfer.op2" or, if op2 file is in the same working directory
".\Modell_prt1_fem1_sim1_Heat_transfer.op2"
Any suggestions will help, best wishes, Miachel
Production: NX10; Development: VB, TCL/TK, FORTRAN; Testing: NX11
Re: Temp Preload from OP2 with relative path
Not at this time. Relative path specification is coming in Simcenter 12.
Sign up to be a beta tester and try it now. Beta started April 24.
JimB,
thank you for that information.
Unfortunately I have not time for beta testing and besides I can't install NX12 beta here on my computer infrastructure for my own.  I don't believe that I'm allowed to take it home and install it there, right?
Best wishes, Michael
Technically, there is no reason you couldn't install it at home. I'm not sure if there is a legal restriction or not. You might contact the beta administrator for clarification.
https://www.plm.automation.siemens.com/en_us/products/nx/nx_beta_testing.shtml
