Transfer from IDEAS to NX
Hi everyone,
I have a problem to transfer my data from IDEAS 7.5 to NX Nastran 9.0, i used the CMM 9.0.2 to do this tranfer. But i don't refind the results of my simulation.
I used the data type from IDEAS : .arc (i find the Fem, and the 3D part), with .mf1 (i find the Fem, the 3D part, the boundary conditions), and with .unv (i find everything).
The big problem is all of our simulation are saved in .arc.
Is anyone familiar with that ?
Thanks for your answer and sorry for my bad english.
Re: Transfer from IDEAS to NX
Dear Colleague
pls provide your email and i will connect you with an expert
pavel.goncharov@siemens.com
Best regards,
Pavel
CMM Native for CAE uses an I-deas Model file as it's source. If your data is stored in a .universal file, archive file or checked into a library, you need to get it into a modef file (import/check out) prior to running CMM.
See the attached docs for more information.
Thanks everyone for your answers.
