What is Teamcenter Simulation?
Siemens Legend Siemens Legend
Siemens Legend
Teamcenter Provides Simulation Data, Workflow and Process Management within Your PLM Environment
The Teamcenter capabilities for simulation process management provide a rich, out-of-the-box data model to manage computer-aided engineering (CAE) specific geometry, meshed models, run ready decks, results, and reports so you can easily find and re-use the right data for your virtual prototypes, as well as achieve complete traceability from requirements to simulation results. When designs change, you can visually compare and rapidly update models and assemblies, regenerate results, and validate the changes.
The Teamcenter scalable framework provides you with easy configuration and launch of CAE applications. Secure and global access to simulation data within your product lifecycle management (PLM) system allows you to share information and collaborate more effectively. Standard workflows to initiate, monitor, review and approve digital prototypes makes your programs more effective. Your entire team can interactively visualize structural, fluid, and motion results without the need for expert tools.
Learn More about Teamcenter Simulation Process Management...
Jerry Sarfati
Siemens PLM Software
