Do you mean
Reply
Solved! Go to solution
What is the difference between Single constraint and Multiple Constraint in the Solution Type
Hi
Could someone tell me the difference between SESTATIC 101 Single constraint and multiple Constraint.
Dinesh
Solution
Solution
Accepted by topic author DineshBabu
‎08-08-2016 01:01 PM
Re: What is the difference between Single constraint and Multiple Constraint in the Solution Type
the clue is in the name! Single constraint means that all subcases have the same constraints, with Multiple Constraint you can define difference constraint for each subcase
