Do you mean
Reply
Solved! Go to solution
Where can i find the document "NX Nastran demonstration problem Manual" ?
I am new user for NX Nastran,
I found there are many simulation examples  (input *.dat documents) in the install_dir\nxnr\nast\demo of NX Nastran,
The explanation for the folder "Demo" in the document "NX Nastran installation and operation Guide", as follows:
"DEMO
The demonstration problem library (install_dir/nxnr/nast/demo on Linux and install_dir\nxnr\nast\demo on Windows) contains a selection of NX Nastran input files that are documented in the NX Nastran Demonstration Problem Manual. "
My question is that,
Solution
Solution
Accepted by topic author WANGHUA198211
‎02-01-2017 05:06 AM
Re: Where can i find the document "NX Nastran demonstration problem Manual" ?
Information can be found in the "NX Nastran Verification Manual".
For Version 11 you find the documentation here:
https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help#uid:xid1128419:xid1128428:index_Verificat...
Hello, BorisL
Thank you very much for your reply !
i got it.
