fluid structure interaction
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
I am trying to model a piece of metal being heated and melting from solid to liquid. I want to model how the metal is melted and the molten metal flow around the unmelted solid metal. So there will be thermal and structural analysis, also fluid flow. I am wondering if virtual fluid mass (MFLUID) of SOL 129 a good choice?
Is there anywhere I can find detailed documentation and additional reading of virtual fluid mass, especially the theory behind it?
Thanks!
Re: fluid structure interaction
You can try to search NX Documentation for information about Mfluid. For more source, you can try to search in NX Nastran Documentation.
However, I dont think phase change (from solid to liquid) is possible in NX yet. The FSI that NX is currently have is a one way interaction, where the Flow analysis is performed first, then following with the Structure analysis where the Flow data is mapped. 2 way interactions is not possible yet.
Kind regards,
Tuw
