heat transfer between solid and fluid
I tried to make a case that a hot fluid transfer heat to the adjacent pipe, but I always get zero heat transfer between solid and fluid, how to setup the interface between solid and fluid?
Re: heat transfer between solid and fluid
Is this a thermal-only or a coupled thermal flow simulation?
Would it be possible to provide a sketch of the scenario you are trying to model?
