Do you mean
Reply
load combinations including bolt preload.
I want to calculate many combinations of loads:
Basic loads:
weight
bolt preload
Lat
Long
Vert
Combinations:
lat+0.3long+0.3vert+weight+bolt \ -0.3lat+long+0.3vert+weight+bolt
lat-0.3long+0.3vert+weight+bolt \ -0.3lat-long+0.3vert+weight+bolt
lat-0.3long-0.3vert+weight+bolt \ -0.3lat-long-0.3vert+weight+bolt
-lat+0.3long+0.3vert+weight+bolt \ -0.3lat+long-0.3vert+weight+bolt
-lat-0.3long+0.3vert+weight+bolt \ 0.3lat+0.3long+vert+weight+bolt
-lat-0.3long-0.3vert+weight+bolt \ 0.3lat-0.3long+vert+weight+bolt
lat+0.3long-0.3vert+weight+bolt \ 0.3lat-0.3long-vert+weight+bolt
-lat+0.3long-0.3vert+weight+bolt \ 0.3lat+0.3long-vert+weight+bolt
0.3lat+long+0.3vert+weight+bolt \ -0.3lat+0.3long+vert+weight+bolt
0.3lat-long+0.3vert+weight+bolt \ -0.3lat-0.3long+vert+weight+bolt
0.3lat-long-0.3vert+weight+bolt \ -0.3lat-0.3long-vert+weight+bolt
0.3lat+long-0.3vert+weight+bolt \ -0.3lat+0.3long-vert+weight+bolt
:eek:
I have used the Results, RMB ; Combined load cases tool to do this but it is really tedious and not user friendly.
How about improving it like the Subcase Association Manager, with the addition of coefficients?
Has anybody another suggestion for quick way of doing combinations?
yours sincerely,
Cyril SAINTIGNY
Re: load combinations including bolt preload.
This could be automated by a journal. Record a journal while you do one of the combinations. Then edit the journal and repeat for the other combinations.
Jim Bernard
Advanced Applications Engineer
Siemens PLM Software
2000 Eastman Dr., Milford, OH 45150-2712
www.siemens.com/plm
Hi Jim,
thank you for the tip, I will try the "journal" tool.
yours sincerely,
Cyril SAINTIGNY
Hi Jim,
I tried but those instructions are not recorded in the journal. Only yhe opening of the menu was recorded.
yours,
Cyril SAINTIGNY
Cyril,
I was referring to the Combination type Results Manipulation tool (Tools --> Results --> Results Manipulation). This is expression based and allows you to combine results across subcases/solutions. It is recorded in a journal.
Jim Bernard
www.siemens.com/plm
