midsurfacing in NX 8
I want to reduce the simulation time for a metallic box. I have tried 3D meshing but it has increased the number of nodes. So, i have been trying 2D meshing but unable to perform midsurfacing. Please help me.
Hi Shelly,   Your question is regarding finite element me...
Community Manager
Hi Shelly,
Your question is regarding finite element meshing, But unfortunately you posted it in a forum about CNC machining software.  There is not a lot of overlap here, so you might not get much of an answer.  But you never know who will show up and contribute.
BTW, did you ever notice that Spock-o-file Sheldon's best friend is named Leonard, but nobody ever makes a Nimoy joke?  Interesting....
Sorry my reply is not very helpful :-/
Derek Hart
... if we're not having fun, we're not doing it right!
Re: midsurfacing in NX 8
Hi Shelly,
I'm glad to help, but I need more information about the issue you're having.  When you say you are unable to perform midsurfacing, does that mean you tried and it didn't work?  Or does it mean you aren't sure how to perform midsurfacing operations in NX?  I would also need to know which version you are using.
If you're unfamiliar with midsurfacing in NX, then I suggest to take a look at the online help documentation which includes a section on midsurfacing.  For NX 8.5, you can view this section here: http://support.industrysoftware.automation.siemens.com/docs/nx/nx85/ugdoc/html_files/nx_help/index.h...
If your problem is more specific, then please reply with more information about the issues you're encountering.
Patrick
