stiifeness
I would like to get stiffeness of a subassembly component with respect to all direction in an assembly. Can anyone suggest me in this regard ?
Thanks in advance
Amit
Amit Nandi
Application Engineer, DesignTech Systems Ltd.
Re: stiifeness
Not sure whether I get your point but, do you mean getting a simple spring constant of the component or something more sophisticated?
If you mean the mentioned spring constant so it's quite easy:
C = F/u , where:
--> F - global load
--> u - magnitude displacement (or directional displacement)
I think, that if you provide more information it will be easier to answer Smiley Happy
