user subroutines
N/A
does NX CAE support user subroutines, where can I find info about what kind of subroutines I can write, in what language and what models can I implement ? i.e. turbulence models, les subgrid models, combustion models etc.
Thank You
Walter
Re: user subroutines
Hello Walter,
yes NX CAE should support user subroutines. At the moment I have no experience with using subroutines in NX, but the Module for creating subroutines in NX is called NX-Open. If you search in NX-Help for "NX Open code examples" maby this can help you a little bit.
