NX License Error: No such featur exists. [-5]
I got my licence for the NX 10 Student Version a week ago but today I got this message when I tried to launch the program:
NX License Error: No such feature exists. [-5]
First it worked fine, I modified a couple of files, but after closing the progam and launching it again this happened. What can/should I do?
Re: NX License Error: No such featur exists. [-5]
Siemens Legend Siemens Legend
Siemens Legend
@julietaayalardz  What were you modifying? The NX program files, or an NX part file?
Try giving NX your license file again.  (See FAQ #7 at:  http://community.plm.automation.siemens.com/t5/NX-Student-Forum/Trouble-Licensing-NX-Learning-Editio...  )
If that fails, I would uninstall NX, make sure all the folders are deleted and re-install.
Jerry
Jerry Sarfati
Siemens PLM Software
I was modifying an NX part file for my homework. I will try to renew the root to my licence via the Setup.exe applicaction and I will let you know how that turned out.
I did what you recommended (give again the root for the licence and uninstall and install again the program) but still get the error: NX License Error: No such featur exists. [-5]. I used the Licensing Tool and found this (images attatched).
What should I do?
Siemens Legend
What is the host ID listed in your License_UGSlmd.txt file?    (example:  HOSTID=9c40b8b08fd9)
What are the Host ID's listed in the Licensing tool?   (in the environment section)
Jerry
Jerry Sarfati
Can you post the license file. I can give it a quick look and let you know what I find.
Lynn Watts
Industry Sector
10824 Hope St.
Cypress, CA, USA
E-mail: lynn.watts@siemens.com
Tel: +1 (714) 952-6501
