3008 (GI) error
HI,
Can someone plz help me.
whenever i run my analysis after 1 or 2 mints. it says that you have insufficent memory for subroutine SSPLID.
can someone plz tell me how can i locate memory in nx nastran?
plz help
Sheheryar Khan
Re: 3008 (GI) error
First, how much memory does your machine have? The f04 file has all of the information concerning performance, if you can post it, it would be easier to see what actually happened. Posting the entire error message might be helpful also.
Assuming your machine has more 16gb of RAM, then you can try using the ILP executable by going to Preferences/Interfaces and check the box for "ILP 64 bit Nastran"
Joe
Re: 3008 (GI) error
Hi Joe,
Thnx for replying.
i attached my error box screenshot and copied .f04 file below.
I checked the option in interface menu and tried to run analysis again but still facing same problem.
And my geometry is also very simple it contains 1 C cross-section spar and skin.
Sheheryar Khan.
.f04 file
1
MACHINE MODEL OPERATING SYSTEM NX Nastran BUILD DATE RUN DATE
Intel64 Family 6 Mod Windows 7 Service Pa VERSION 11.0.2 MAY 8, 2017 NOV 14, 2017
=== N X N a s t r a n E X E C U T I O N S U M M A R Y ===
Day_Time Elapsed I/O_Mb Del_Mb CPU_Sec Del_CPU Subroutine
8:58:15 0:00 0.0 0.0 0.0 0.0 SEMTRN BGN
8:58:15 0:00 0.0 0.0 0.0 0.0 SEMTRN END
8:58:15 0:00 0.0 0.0 0.0 0.0 DBINIT BGN
** CURRENT PROJECT ID = ' "BLANK" ' ** CURRENT VERSION ID = 1
S U M M A R Y O F F I L E A S S I G N M E N T F O R T H E P R I M A R Y D A T A B A S E ( DBSNO 1, NXN11.2 )
ASSIGNED PHYSICAL FILE NAME (/ORIGINAL) LOGICAL NAME DBSET STATUS BUFFSIZE CLUSTER SIZE TIME STAMP
d:/.../c 1 spar-000.T3536_14.MASTER MASTER MASTER NEW 32769 1 171114085815
d:/.../femap/c 1 spar-000.T3536_14.DBALL DBALL DBALL NEW 32769 1 171114085816
d:/.../c 1 spar-000.T3536_14.OBJSCR OBJSCR OBJSCR NEW 8193 1 171114085817
**** MEM FILE **** * N/A * SCRATCH
d:/.../c 1 spar-000.T3536_14.SCRATCH SCRATCH SCRATCH NEW 32769 1 171114085818
d:/.../c 1 spar-000.T3536_14.SCR300 SCR300 SCRATCH NEW 32769 1 171114085819
8:58:15 0:00 3.0 3.0 0.0 0.0 DBINIT END
8:58:15 0:00 3.0 0.0 0.0 0.0 XCSA BGN
S U M M A R Y O F F I L E A S S I G N M E N T F O R T H E D E L I V E R Y D A T A B A S E ( DBSNO 2, NXN11.2 )
d:/progra~1/.../em64tnt/SSS.MASTERA MASTERA MASTER OLD 8193 1 170411165315
/./sss.MASTERA
d:/progra~1/.../em64tnt/SSS.MSCOBJ MSCOBJ MSCOBJ OLD 8193 1 170411165320
/./sss.MSCOBJ
d:/progra~1/.../em64tnt/SSS.MSCSOU MSCSOU MSCSOU OLD 8193 1 170411165321
/./sss.MSCSOU
8:58:15 0:00 140.0 137.0 0.1 0.1 XCSA END
8:58:15 0:00 140.0 0.0 0.1 0.0 CGPI BGN
8:58:15 0:00 140.0 0.0 0.1 0.0 CGPI END
8:58:15 0:00 140.0 0.0 0.1 0.0 LINKER BGN
8:58:15 0:00 227.0 87.0 0.1 0.0 LINKER END
S U M M A R Y O F P H Y S I C A L F I L E I N F O R M A T I O N
ASSIGNED PHYSICAL FILE NAME RECL (BYTES) MODE FLAGS WSIZE (WNUM)
d:/program files/siemens/femap/c 1 spar-000.T3536_14.SCRATCH 131072 R/W N/A
d:/program files/siemens/femap/c 1 spar-000.T3536_14.OBJSCR 32768 R/W N/A
d:/program files/siemens/femap/c 1 spar-000.T3536_14.MASTER 131072 R/W N/A
d:/program files/siemens/femap/c 1 spar-000.T3536_14.DBALL 131072 R/W N/A
d:/program files/siemens/femap/c 1 spar-000.T3536_14.SCR300 131072 R/W N/A
d:/progra~1/siemens/nastran/nxn11p02/em64tnt/SSS.MASTERA 32768 R/O N/A
d:/progra~1/siemens/nastran/nxn11p02/em64tnt/SSS.MSCOBJ 32768 R/O N/A
FLAG VALUES ARE --
B BUFFERED I/O USED TO PROCESS FILE
M FILE MAPPING USED TO PROCESS FILE
R FILE BEING ACCESSED IN 'RAW' MODE
ASSIGNED PHYSICAL FILE NAME LOGICAL UNIT STATUS ACCESS RECL FORM FLAGS
c:/users/lenovo/.../tail structure/c spar/c 1 spar-000.f04 LOGFL 4 OLD SEQ N/A FMTD
c:/users/lenovo/.../tail structure/c spar/c 1 spar-000.f06 PRINT 6 OLD SEQ N/A FMTD
d:/progra~1/siemens/nastran/nxn11p02/nast/news.txt INCLD1 9 OLD SEQ N/A FMTD R
c:/users/lenovo/.../tail structure/c spar/c 1 spar-000.plt PLOT 14 OLD SEQ N/A UNFMTD
c:/users/lenovo/.../tail structure/c spar/c 1 spar-000.op2 OP2 12 OLD SEQ N/A UNFMTD
d:/program files/siemens/femap/c 1 spar-000.T3536_14.f18 OUTPUT2 18 UNKNOWN SEQ N/A UNFMTD
d:/program files/siemens/femap/c 1 spar-000.T3536_14.f19 INPUTT4 19 OLD SEQ N/A UNFMTD R
c:/users/lenovo/.../tail structure/c spar/c 1 spar-000.f56 F56 56 UNKNOWN SEQ N/A FMTD
c:/users/lenovo/.../tail structure/c spar/c 1 spar-000.pch PUNCH 7 OLD SEQ N/A FMTD
c:/users/lenovo/.../tail structure/c spar/c 1 spar-000.xdb DBC 40 UNKNOWN DIRECT 1024 UNFMTD
c:/users/lenovo/.../tail structure/c spar/c 1 spar-000.asm ASSEM 16 OLD SEQ N/A FMTD
FLAG VALUES ARE --
A FILE HAS BEEN DEFINED BY AN 'ASSIGN' STATEMENT
D FILE IS TO BE DELETED BEFORE RUN, IF IT EXISTS
R FILE IS READ-ONLY
T FILE IS TEMPORARY AND WILL BE DELETED AT END OF RUN
** PHYSICAL FILES LARGER THAN 2GB ARE SUPPORTED ON THIS PLATFORM
0 ** MASTER DIRECTORIES ARE LOADED IN MEMORY.
USER OPENCORE (HICORE) = 572821680 WORDS
EXECUTIVE SYSTEM WORK AREA = 316925 WORDS
MASTER(RAM) = 79892 WORDS
SCRATCH(MEM) AREA = 191108808 WORDS ( 5832 BUFFERS)
BUFFER POOL AREA (GINO/EXEC) = 191068791 WORDS ( 5829 BUFFERS)
TOTAL NX NASTRAN MEMORY LIMIT = 955396096 WORDS
Day_Time Elapsed I/O_Mb Del_Mb CPU_Sec Del_CPU SubDMAP Line (S)SubDMAP/Module
8:58:15 0:00 228.0 1.0 0.1 0.0 XSEMDR BGN
8:58:15 0:00 228.0 0.0 0.1 0.0 SEFLUTTR33 (S)SUPER1 BEGN
8:58:15 0:00 229.0 1.0 0.1 0.0 SUPER1 25 (S)IFPL BEGN
8:58:15 0:00 229.0 0.0 0.1 0.0 IFPL 38 IFP1 BEGN
8:58:15 0:00 229.0 0.0 0.1 0.0 IFPL 133 XSORT BEGN
8:58:22 0:07 469.0 240.0 7.6 7.5 IFPL 133 XSORT END
8:58:22 0:07 469.0 0.0 7.6 0.0 IFPL 160 COPY BEGN
8:58:22 0:07 469.0 0.0 7.9 0.3 IFPL 182 FORTIO BEGN
8:58:22 0:07 469.0 0.0 7.9 0.0 IFPL 216 (S)IFPS BEGN
8:58:22 0:07 469.0 0.0 7.9 0.0 IFPS 30 IFP BEGN
8:58:23 0:08 469.0 0.0 7.9 0.0 IFP
* COUNT:ENTRY COUNT:ENTRY COUNT:ENTRY COUNT:ENTRY COUNT:ENTRY COUNT:ENTRY *
* 1:AERO 1:CAERO1 1:CORD2C 1:CORD2S 996199:CTETRA 1:EIGRL *
* 3:FLFACT 1:FLUTTER 1614340:GRID 1:MAT1 1:MAT4 3:MKAERO2 *
* 1Smiley TongueAERO1 5Smiley TongueARAM 1Smiley TongueSHELL 1Smiley TongueSOLID 1Smiley FrustratedET1 1062Smiley FrustratedPC1 *
* 1Smiley FrustratedPLINE1
* PARAM: AUTOSPC GRDPNT OGEOM POST PRGPST *
8:58:28 0:13 469.0 0.0 13.0 5.2 IFPS 30 IFP END
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 32 (S)TESTBIT BEGN
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 34 (S)TESTBIT BEGN
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 36 (S)TESTBIT BEGN
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 59 (S)TESTBIT BEGN
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 61 (S)TESTBIT BEGN
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 63 (S)TESTBIT BEGN
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 65 (S)TESTBIT BEGN
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 72 CHKPNL BEGN
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 73 DMIIN BEGN
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 84 DTIIN BEGN
8:58:28 0:13 469.0 0.0 13.0 0.0 IFPS 181 MODGM2 BEGN
8:58:31 0:16 469.0 0.0 15.6 2.6 IFPS 181 MODGM2 END
8:58:31 0:16 469.0 0.0 15.6 0.0 IFPS 193 MODGM2B BEGN
8:58:31 0:16 469.0 0.0 15.6 0.0 IFPS 202 PVT BEGN
8:58:31 0:16 469.0 0.0 15.6 0.0 IFPS 222 GP1LM BEGN
8:58:31 0:16 469.0 0.0 15.6 0.0 IFPS 223 GP1 BEGN
8:58:31 0:16 486.0 17.0 16.1 0.4 IFPS 347 GP7 BEGN
8:58:31 0:16 486.0 0.0 16.1 0.0 IFPL 221 SEPR1 BEGN
8:58:31 0:16 486.0 0.0 16.1 0.0 IFPL 222 DBDELETEBEGN
8:58:31 0:16 486.0 0.0 16.1 0.0 IFPL 237 PROJVER BEGN
8:58:31 0:16 486.0 0.0 16.1 0.0 IFPL 242 PVT BEGN
8:58:31 0:16 487.0 1.0 16.1 0.0 IFPL 276 (S)IFPS1 BEGN
8:58:31 0:16 487.0 0.0 16.1 0.0 IFPS1 15 DTIIN BEGN
8:58:31 0:16 487.0 0.0 16.1 0.0 IFPS1 47 PLTSET BEGN
8:58:31 0:16 487.0 0.0 16.3 0.2 IFPS1 50 MSGHAN BEGN
8:58:31 0:16 487.0 0.0 16.3 0.0 IFPS1 51 MSGHAN BEGN
8:58:31 0:16 487.0 0.0 16.3 0.0 IFPS1 52 GP0 BEGN
8:58:31 0:16 487.0 0.0 16.3 0.0 IFPS1 58 MSGHAN BEGN
8:58:31 0:16 487.0 0.0 16.3 0.0 IFPL 278 (S)TESTBIT BEGN
8:58:31 0:16 487.0 0.0 16.3 0.0 SUPER1 115 (S)PHASE0 BEGN
8:58:31 0:16 487.0 0.0 16.3 0.0 PHASE0 79 (S)TESTBIT BEGN
8:58:31 0:16 487.0 0.0 16.3 0.0 PHASE0 80 (S)TESTBIT BEGN
8:58:31 0:16 488.0 1.0 16.3 0.0 PHASE0 98 PVT BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 99 COPY BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 106 PROJVER BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 109 DTIIN BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 153 OUTPUT2 BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 170 OUTPUT2 BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 185 OUTPUT2 BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 193 (S)TESTBIT BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 194 (S)TESTBIT BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 195 (S)TESTBIT BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 306 SEP1X BEGN
8:58:31 0:16 488.0 0.0 16.3 0.1 PHASE0 319 GP1LM BEGN
8:58:31 0:16 488.0 0.0 16.3 0.0 PHASE0 324 GP1 BEGN
8:58:32 0:17 501.0 13.0 16.7 0.4 PHASE0 324 GP1 END
8:58:32 0:17 501.0 0.0 16.7 0.0 PHASE0 330 GP2 BEGN
8:58:34 0:19 501.0 0.0 18.5 1.7 PHASE0 330 GP2 END
8:58:34 0:19 502.0 1.0 18.5 0.0 PHASE0 418 TA1 BEGN
8:58:39 0:24 2139.0 1637.0 22.5 4.0 PHASE0 418 TA1 END
8:58:39 0:24 2139.0 0.0 22.6 0.1 PHASE0 423 TASNP2 BEGN
8:58:39 0:24 2313.0 174.0 23.1 0.5 PHASE0 428 SEP1 BEGN
8:58:40 0:25 2314.0 1.0 23.2 0.2 PHASE0 474 GP1 BEGN
8:58:41 0:26 2558.0 244.0 23.7 0.5 PHASE0 474 GP1 END
8:58:41 0:26 2558.0 0.0 23.7 0.0 PHASE0 480 (S)AERO0 BEGN
8:58:41 0:26 2558.0 0.0 23.7 0.0 AERO0 38 AEMODEL BEGN
8:58:41 0:26 2558.0 0.0 23.7 0.0 AERO0 40 APD BEGN
*8** Module DMAP Matrix Cols Rows F T NzWds Density BlockT StrL NbrStr BndAvg BndMax NulCol
APD 40 MPJSFN2O 1200 200 2 2 2 8.33333D-04 3 0 200 0 1 1000 *8**
8:58:41 0:26 2559.0 1.0 23.7 0.0 AERO0 56 GI BEGN
GI 56 SCR 304 200 363 2 2 24 3.30579D-02 3 4 600 39 39 0 *8**
GI 56 SCR 305 693 363 2 2 24 3.30579D-02 3 4 2079 39 39 0 *8**
GI 56 SCR 307 1200 363 2 2 24 3.30579D-02 3 4 3600 39 39 0 *8**
GI 56 SCR 306 363 363 6 2 54 6.56376D-02 3 8 1035 68 75 0 *8**
GI 56 SCR 307 363 200 2 2 44 3.30579D-02 3 2 936 20 36 93 *8**
GI 56 SCR 308 363 363 1 2 54 4.65815D-02 3 8 744 49 75 93 *8**
GI 56 SCR 309 363 363 1 2 54 6.56376D-02 3 8 1023 68 75 0 *8**
*** USER INFORMATION MESSAGE 4157 (DFMSYO)
PARAMETERS FOR SPARSE DECOMPOSITION OF DATA BLOCK SCRATCH ( TYPE=RDP ) FOLLOW
MATRIX SIZE = 363 ROWS NUMBER OF NONZEROES = 4506 TERMS
NUMBER OF ZERO COLUMNS = 0 NUMBER OF ZERO DIAGONAL TERMS = 0
User information:
When spill is indicated, the model is too large to fit into memory.
The job may run faster by increasing the available memory (this will
decrease the number of spill groups).
See the NX NASTRAN Installation and Operation Instructions for a
description of these terms. See also the NX NASTRAN Numerical
Methods User's Guide.
CPU TIME ESTIMATE = 0 SEC I/O TIME ESTIMATE = 0 SEC
MINIMUM MEMORY REQUIREMENT = 84 KB MEMORY AVAILABLE = 2237536 KB
MEMORY REQR'D TO AVOID SPILL = 636 KB MEMORY USED BY MINDG = 48 KB
EST. INTEGER WORDS IN FACTOR = 7 K WORDS EST. NONZERO TERMS = 15 K TERMS
ESTIMATED MAXIMUM FRONT SIZE = 78 TERMS RANK OF UPDATE = 128
*** USER INFORMATION MESSAGE 6439 (DFMSA)
ACTUAL MEMORY AND DISK SPACE REQUIREMENTS FOR SPARSE SYM. DECOMPOSITION
User information:
This message is issued in the .F04 file after decomposition.
It tells how much memory and desk space were actually required.
SPARSE DECOMP MEMORY USED = 600 KB MAXIMUM FRONT SIZE = 78 TERMS
INTEGER WORDS IN FACTOR = 2 K WORDS NONZERO TERMS IN FACTOR = 15 K TERMS
SPARSE DECOMP SUGGESTED MEMORY = 600 KB
*8** Module DMAP Matrix Cols Rows F T IBlks NBlks NumFrt FrtMax
GI 56 SCR 307 363 363 13 2 1 1 29 78 *8**
GI 56 SCR 308 200 363 2 2 726 1.00000D+00 7 355 204 363 363 0 *8**
GI 56 SCR 307 200 693 2 2 1386 1.00000D+00 11 666 208 693 693 0 *8**
GI 56 SCR 304 693 200 2 2 400 1.00000D+00 11 197 701 200 200 0 *8**
GI 56 GPKSK 462 1200 2 2 400 1.66667D-01 13 1 92400 1195 1195 0 *8**
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 56 GI END
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 69 MKCSTMA BEGN
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 73 GETMKL BEGN
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 76 MKCSTMA BEGN
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 80 AEMODEL BEGN
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 84 DMIIN BEGN
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 85 MKCNTRL BEGN
MKCNTRL 85 TRX 1 6 2 2 0 0.00000D+00 3 0 1 0 0 1 *8**
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 86 MKCSTMA BEGN
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 89 MAKAEMONBEGN
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 92 MAKCOMP BEGN
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 93 MAKMON BEGN
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 94 MRGMON BEGN
8:58:43 0:28 2559.0 0.0 23.7 0.0 AERO0 95 MONVEC BEGN
MONVEC 95 SRKS 6 1200 2 2 2000 5.00000D-01 3 2 1202 1197 1200 0 *8**
8:58:43 0:28 2560.0 1.0 23.7 0.0 AERO0 112 UPARTN BEGN
UPARTN 112 SCR 301 1 1200 2 1 800 6.66667D-01 3 1 401 1200 1200 0 *8**
UPARTN 112 SAEMPRK 6 400 2 2 800 5.83333D-01 3 2 602 332 400 1 *8**
8:58:43 0:28 2561.0 1.0 23.7 0.0 AERO0 118 MAKCOMP BEGN
8:58:43 0:28 2561.0 0.0 23.7 0.0 AERO0 119 MAKMON BEGN
8:58:43 0:28 2561.0 0.0 23.7 0.0 AERO0 120 MRGMON BEGN
8:58:43 0:28 2561.0 0.0 23.7 0.0 AERO0 122 MONVEC BEGN
MONVEC 122 SAERG1 6 9686040 2 2 9686040 3.33333D-01 1973 1 12915017 9686037 9686040 0 *8**
8:58:45 0:30 2772.0 211.0 25.0 1.3 AERO0 122 MONVEC END
XEQUIV 138 SAERG0 6 9686040 2 2 9686040 3.33300D-01 1973 1 12915017 9686037 9686040 0 *8**
8:58:45 0:30 3020.0 248.0 25.2 0.2 AERO0 143 MKSPLINEBEGN
8:58:45 0:30 3020.0 0.0 25.2 0.0 AERO0 147 GI BEGN
*** TOTAL MEMORY AND DISK USAGE STATISTICS ***
+---------- SPARSE SOLUTION MODULES -----------+ +------------- MAXIMUM DISK USAGE -------------+
HIWATER SUB_DMAP DMAP HIWATER SUB_DMAP DMAP
(WORDS) DAY_TIME NAME MODULE (MB) DAY_TIME NAME MODULE
382739397 08:58:41 AERO0 56 GI 1444.438 08:58:39 PHASE0 418 TA1
*** DATABASE USAGE STATISTICS ***
+------------------ LOGICAL DBSETS ------------------+ +------------------------- DBSET FILES -------------------------+
DBSET ALLOCATED BLOCKSIZE USED USED FILE ALLOCATED HIWATER HIWATER I/O TRANSFERRED
(BLOCKS) (WORDS) (BLOCKS) % (BLOCKS) (BLOCKS) (MB) (GB)
MASTER 5000 32768 52 1.04 MASTER 5000 52 6.500 0.133
DBALL 2000000 32768 1983 0.10 DBALL 2000000 1983 247.875 0.245
OBJSCR 5000 8192 318 6.36 OBJSCR 5000 318 9.938 0.012
SCRATCH 4005832 32768 12615 0.31 (MEMFILE 5832 5832 729.000 0.000)
SCRATCH 2000000 8755 1094.375 1.338
SCR300 2000000 5241 655.125 1.137
TOTAL: 2.866
*** BUFFER POOL AND SCRATCH 300 USAGE STATISTICS ***
+----------------- BUFFER POOL -----------------+ +-------------------------- SCRATCH 300 --------------------------+
OPTION BLOCKS BLOCKS BLOCKS OPTION HIWATER SUB_DMAP DMAP OPN/CLS
SELECTED ALLOCATED REUSED RELEASED SELECTED (BLOCKS) DAY_TIME NAME MODULE COUNTER
GINO,EXEC 5829 14604 12479 2 5241 8:58:39 PHASE0 418 TA1 2
*** SUMMARY OF PHYSICAL FILE I/O ACTIVITY ***
ASSIGNED PHYSICAL FILE NAME RECL (BYTES) READ/WRITE COUNTS WSIZE (WNUM) MAP-I/O CNT
d:/program files/siemens/femap/c 1 spar-000.T3536_14.SCRATCH 131072 1405/9557 N/A N/A
d:/program files/siemens/femap/c 1 spar-000.T3536_14.OBJSCR 32768 2/401 N/A N/A
d:/program files/siemens/femap/c 1 spar-000.T3536_14.MASTER 131072 12/1082 N/A N/A
d:/program files/siemens/femap/c 1 spar-000.T3536_14.DBALL 131072 4/2007 N/A N/A
d:/program files/siemens/femap/c 1 spar-000.T3536_14.SCR300 131072 3705/5607 N/A N/A
d:/progra~1/siemens/nastran/nxn11p02/em64tnt/SSS.MASTERA 32768 73/0 N/A N/A
d:/progra~1/siemens/nastran/nxn11p02/em64tnt/SSS.MSCOBJ 32768 314/0 N/A N/A
Re: 3008 (GI) error
Please try running with the ILP executable and also the setting "buffsize=65537" shown below. If that does not allow it to run, then the best option is to open a ticket with GTAC or share the model here if possible.
Joe
Re: 3008 (GI) error
Hi Joe,
Thnx for your time.
i will try it and then let you know but i am encountring new error when i import mesh after importing geometry, error message shows up.
below are the screenshots attached.
Plz help me in that because i cant even tart my analysis earlier there was no error. But now when i import ansys mesh it give errors and says Property 0 doesnt exist. Reference to Element 1-101.
i am importing .nas mesh file from ansys into nx nastran and geometry file is .x_t.
Rrgards
Sheheryar Khan
